apply materials
  • Thread starter Thread starter Aceto
Aceto
hi to all .sto using autocad 2008.I downloaded a dwg to create a galvanizing effect material.This works on small solids while, I think I understand, it "distributes" on larger solids.in fact if the small object joins it, it also stretches the "skin". Can someone give me advice?
If you want advice I would create a custom mapping and after if necessary I use autocad options to adapt textures to the surface.
It seems more professional.
Hello everyone,
I am a new adept:).... feel I need some advice ... I have a building all shaped with cad to which I added as a lock of the capitals.
the problem is that I can't add the texture on the block...so that you have to go on the editor blocks though I don't know how it works. Can anyone help me??? Thank you.
