appraisal torino approved
  • Thread starter Thread starter Andryx
Andryx
Hello I would need a report of a mechanical naïre enrolled in the atbo to homologate a measure of tires to my bike is there someone who can help me?
You don't need an engineer!
You need the building's nothing
with the new regulations if the building house does not release the obsta nothing you can go from a naive get the expertise that those tires do not create problems and after that with that go in motorization and fix the appointment for testing. the problem and that I do not find a naive enrolled in the albo.
So... .
http://bfy.tw/46g1
holye...http://lmgtfy.com/works like google, but it allows you to have a link that makes the animation you saw
I thank you mtb for me is absolutely new, I knew nothing about its existence. I learned another new thing from the forum, which will accompany the many other learned from cad3d. Thanks...
try to call tüv or similar organisms. may give you useful directions or names.
in the past I remember that it was possible, to avoid certain "italianate" , to homologate a car in an exemplary unique in germany (of course with technical relations, calculations and costs of the case) . then Italy was forced to homologate because a Member State cannot refuse the homologation of a vehicle homologated in another European country .
Did you check if your bike is approved in some other European country with that tyre size?
