sanpol
Good morning to all,
I'm a designer and I'm just looking at the design with solidworks as my new work assignment concerns plastic products with injection molding. Before now I used rhinoceros, but the design approach and totally different and from what I saw solidworks is much more suitable and possesses unthinkable automatisms with rhino.
Until it comes to square mechanical parts I have no big problems setting the design but with less geometric objects I don't know how to approach. I would kindly like a push in this direction from you who have more experience. Since each project is different from another I would just like to try to understand the method. a first example I would like to submit to you and this bowl that has a descending side. the plant is a perfectly symmetrical oval on the 2 axis and the object is symmetrical compared to the yz plane.
This you see I made it with ease in rhino, but I would like to parameterize it in solidworks to vary sizes, thicknesses and make reinforcement fins and correct sform angles.
I thought I would create a sketch on the upper floor for the base oval, then extrude to the correct height and then realize an extruded cut to get the inside compartment... But then? How do I realize the descending edge? I got stuck here.
.I thought I would create a sketch on the upper floor for the base oval, then extrude to the correct height and then realize an extruded cut to get the inside compartment... But then? How do I realize the descending edge? I got stuck here.
