zerbo1000
Good evening, gentlemen.
is it possible in autocad 3d 2016 to make a 3d arc (i.e. on a different plane from the classic xy in 2d) without using things like turning the work plane or making a 2d arc and then curve it with 3d wheel? i.e. how it is possible to make by spline or lines, simply rotating the view the program cad "nose" understands the plan on which we want to work and drawing on the same.. .
Thank you
a hug
Thank you
a hug
