archicad 8
  • Thread starter Thread starter archale
archale
...I learned to work on version 8 and I would like to buy the license.... help??? ? :tongue:
.... then they started a newer version... but for the moment I want to... regulate version 8.
you would like to hear the ciragraph/graphisoft area distributor and see if you can still purchase a license so dated
there is not then this difference between archicad 8 or 10...11...I would buy the last one, also because I don't know if then you can install it on pc that have operating systems like windows view or seven.I have seen and I had to install the 11
I think it's not true, archicad has made a big leap forward from version 10 onwards. test archicad 9 after using archicad 12 or 13 and the differences known all. with the 8 that I have never used, I imagine it is even more evident
I used both the 8th, the 9th and now the 11th...and if you know how to use an earlier is that you can not use the newest version... I wanted to say this. you don't want to buy an old version
