archicad: problems with creating objects
  • Thread starter Thread starter Andrea.90
Andrea.90
Good morning to all, I am new to this forum... while I was using archicad I met a complication. . normally when save 3d objects with the usual method there are no problems and it always worked... while the last time I tried with a two-storey building does not work: I create the object normally with the usual procedure and save it format... when then I try to use it and then to insert it into a 3d model the object only presents the plant and if control in the 3d there is nothing... Can you help me?? Thanks for the good day:-) :finger:
