architectural design and verification of wooden structures
  • Thread starter Thread starter Giontra
Giontra
Hello everyone, I am an industrial engineer but I would like to try out the design and design of a wooden house. in this regard I wanted advice on cad 3d that have the possibility to model wooden structures and to make it structural verification. Turning around a bit I found the cad graitec advanced design that makes both things think, then mastersap that with the master module allows verification but I think it is not a modeler. I don't know if revit is a good modeler for wooden structures.
I hope I have some advice on this.
giontra
mastersap you well to make calculations, more difficult to shape the structure.
advance design should be similar to mastersap, has design modles for steel (advance steel) and cement (advance concreate). I don't know if he has something specific to wood.
revit is an architecture software, si revit structure also allows the design of the structures but I do not know if you do your case.in any case connected to robot allows to make calculations even if the correspondence to the Italian norm is to be checked. definitely supports Eurocodes.
Googlando I found this cadworkI don't know him.
