Stefano.bp
hello to all, as I have to return a building that presented some walls tapered in top I thought to avail myself of the architectural pillars, for the particularity of these to be associated with roofs.
I have created two types, one without opening (pillars 1 and 3) another which presents an opening between the two rooms in the attic (pilastro 2), I would have these short questions in the hope that someone has the corstesia to answer me:
1) Can this way of working be corrected to resolve the situation I described?
2) how can I quote the opening (pilastro 2)with a door-type label? (It is not possible to put the doors in the pillar if I do not go wrong, it does not make me do it... )
3) I would have liked to insert a parameter of presence of the opening so that I have only one family of pillars where I could "light or turn off" the opening, but the vacuum (with which I created the opening) does not have a visibility property that is possible to assign to a si/no parameter, can you do otherwise?
4) :smile: a more soul can help me to understand why with the same association settings on the roof and the same positioning plans the pillar 1 and 3 are correctly associated with the roof while the pillar 2 is interrupted to a xxx share when associated (we will be a problem determined by opening)? ?
I attach images and families in case someone could give me an idea.
Thank you in advance.
