arrangement property
  • Thread starter Thread starter fratello
fratello
I wanted to know if it was possible to import arrangements between a view and another.
for example I make a front view... then to give evidence to some details through the color change arrangement properties to some components, when I make the side view I would like the highlighted details to have the same color of the front view.... is it possible?
I remember little drawing, so if someone can help you I hope you do it, anyway I try:
the arrangement property seems to me to act only on the selected view without possibility to import in the various views.. .
But you could:
1) use the 3d color option in the properties/view/detail so as to import the diversified colors you used in the body
2) If you do not want to use body colors (or have not colored them) you can color the parts (or body in case of multibody) in the product and always use the 3d color option
3) if you do not want to color the product, you can create one or more scenarios (which do not affect the product and parts) and color parts or body of multibody independently from the product
4) sometimes the plotter/printer is only in b/n, so it is better to highlight details by changing thickness or type of line but the speech is a little more laborious:
project what you want with a certain characteristic (hiding the rest in 3d),
selections with a traplon all views and apply properties,
return to 3d hide those parts and view others,
returns in drawing and updating,
selections with a trap and apply the other properties you want
When you're done, go back to 3D, see everything,
returns in drawing and updating, the update generates all visible entities while maintaining the properties assigned previously.
Let me know.
Bye-bye
