arrow with text and information
  • Thread starter Thread starter braunfish
braunfish
I have a sheet with 50 design of 50 shaped plates.
for each I should put a dart with text, with these parameters indicated:
- part number (part number)
- mass
- nr. pieces (quantity)
a) if I do it manually I can do the first 2 but I can't put the amount, in the sense that I don't know where to go to take the parameter. (in the drawing together, in the list parts, the quantity appears correct).
b) Do I have to do it by hand for all 50 pieces or can I automate this?
we say that through the styles of ball, I created a ball that automatically puts me the name and weight of the part.
the problem is the quantity: if one the ball on the drawing of a component part of a set the quantity is correct, if I use the ball on the individual design of the part does not work.
It's a bit like the location brand: the components in a set are automatically numbered, the individual parts have all number 1.
I think I'm very close to the solution. Help!
the fact is that when drawing an axieme, inventor knows how many times each part is contained in it. when you make a drawing of a part, instead, you cannot know, and even if it were able there would be the problem that a same .ipt could be inserted into several different assemblies, maybe in a 3 times, in a 5, in a 2... then what amount should you put?
I hoped that by inserting the design of the part into the same sheet with the design of the axieme there could be a link.
Anyway thank you very much for the interest.
Bye!
However there is a way, not comfortable but it works: insert the axieme and hide all the parts except what you care about, then make the ball. Of course doing it 50 times is not the maximum of fun. . .
