mgdi
Today I come back to find you after a little absence because I invented this..... (it really is a little that I think about it but only for a few days I started to try with lean results. )
everything comes from the idea of speeding up and automating a minimum of work.
I have a part where I change for example a radius according to the needs.
I have a family table where to report the value of this beam appropriately associated with a parameter.
I thought I would add a column/parameter to the family table of the Boolean type "print si/no" to "filtrate" the rays I need (I must order the particular in n variants with n ray and not all x variants).
I make a table with general view and family table and filter on "print yes".
all this easy.
would be possible to create automatically in the same drw n sheets one for each of the n variants from family table with "print yes"? to create dxf quickly with a macro.all with creo 3.0 b000, no pdm
an early thanks to those who have ideas to share or solutions! ! ! !
all this easy.
