asked about "sheet converts". . .
  • Thread starter Thread starter PiegatoreSolidworks
PiegatoreSolidworks
according to you can convert this particular sheet metal for development and cutting? sincerely I tried for little and only my curiosity.
but, I looked at it, but it seems a little messed up, first of all the thicknesses are not regular.
I don't think the propeller can be turned into sheet metal.
we say that I drew it as if it was a fried piece only to convert it into sheet metal, but in reality I do it from a plate 20x4 in copper. .
more than convert it you can try to do it directly in sheet, with the loft:View attachment 22253
qui il file: View attachment 22252the thing works, but development may be a little unlikely even if somehow feasible.
Marco:smile:
thanks sampom, definitely a great solution even if I didn't understand much of propellers....adesso I look at the guide and try to do it...practically the loft you do it between 2 props?
...practically the loft you do it between 2 propellers?
Yes. between the 2 3d sketches obtained from the propellers. Can you see the file? Try to inspect the "retrose" tree, it is simple as modeling, you should understand well.
with that system we get some "pseudo developments" for the screws, look:
Mar
Mar
I've never seen anything like that! But then how do you realize it? What kind of "calandra" do you use? I'm curious. .
and the pseudo development is okay or you have to correct it?
I was talking about "pseudo" development:biggrin:. with the cad representation do what you want, the realization then is another pair of sleeves.
However, those are not made of calandra (not in the narrow sense of the communes); who makes coclee starts from a "piatto" (a little like your copper foil) that is "around" around a round soul (a bar or a tube) through a kind of lathe and properly guided.. (there are some videos on youtube, try to search).
only that the size of the resulting section will no longer be the original ones. for "striction" you have that the dish will be thinner and lower (usually. but depending on the method used may also be higher).. the difficulty in predicting this change of size is the problem that is in the process of design/design; you have to tell the operator which bar to take to get some result. but who does that job has enough experience to know "memory" how to operate. a little like for the plates, you have to audit the machine, detect and report the data on the cad.
Marco:smile:
