assembly cutting components
  • Thread starter Thread starter 3dxx
3dxx
My aim is to insert parts into a set with cutting parts.
For example, I created a component with family table and I would like to define surfaces that make me cut when I go to assemble my design.
Is there a way to do this?
thank you all for the answers.
Does anyone have any idea how I can do what I have in mind, or suggest a method on how to proceed?
Once you insert the parts into the axieme, there are 2 ways to do that, single cut in one part and cut directly together.
if you want to get the cut in one component do as follows:
activate the part where you want the cut to be created (from the top), select the cut surface, then click the solidify control and hold the part you want to change direction to the arrow. in this way you get the cut in one component and the cut feature will position itself inside the cut part thus keeping the clean axieme.
if invence you want to get the cut of several parts in one shot only(the method I use), do the same exact procedure (maintaining active the assembling), including/exluding according to the needs the parts to be cut! if you want the cut to see esclisively together, assign first level, otherwise level part.
pro and, by default, cuts everything you are intersected by assigning first level.
That's what I've always done until now.
example:
My purpose is to add a screw as a family table component, and immediately cut the parts that intersect the components to my screw, without having to cut all the components by hand.
the thing I want to get is like the emx module, you have to define in the part the surface to use for cutting.
I hope I've been clearer.
You could make a user-defined feature that does the hole and mount the screw all at once.
Bye.
