assembly problem
  • Thread starter Thread starter CRAZYMAD
CRAZYMAD
hi guys, today's problem is the assieme this unknown:finger: I have been praying that it has long been that I no longer follow a modeling course, as I have now passed to the sole management, but since I have several "private" passions I have been devoting myself to the design of a group, on paper it works as a god but when I try to make the aid, I lose, maybe I have forgotten many fundamental steps.
Some pious soul who wants to give an eye to my little project and explain where am I wrong? ? ?
the project in being is made on solidworks 2010 and I try to replicate an avant-garde of a remote controlled car. give me a :4460: what saves me?
below you will find the entire project
look that there is nothing particularly absurd only I can not give constraints to some pieces. and opening the project to an experienced person would be immediately clear, on do not timid.
but exactly what is the coupling that does not serve you? For example, I saw that you could put the limits on the thorns.
If you look at the particular 009 I can't limit the movimeto of the 2 pins relative to the asola that should act with the thorns as a stick.
then that kind of uniball that there is I can't make him limit the movements to the floor where they would go to slam into reality
take the cylindrical plug and the ties concetrically with the end of the piece 9 asola and then in the advanced couplings put the minimum and maximum (maximum corresponds with the end of the asola). then in piece 008 use plan 1 and give it symmetry (advanced couplings) with the faces of its plug
I correct myself, do not use conventric coupling, I put plan 1 of the plug coincident with the right plan of piece 9. would remain to be defined the bond for the limit of the movement. But let me know where you are. I would but I have 2012 so I can't save.
I don't get symmetry
you took face 1 of the plug and symmetrical it over plane1 and what other element do you use?
or am I wrong?
I should find a tutorial here I don't jump out I don't understand where I'm wrong
to symmetrical the plug:
choose advanced mating mode; select the two faces of the asola and as a symmetry plane 1 of the pin.
tells me that this mating cannot be satisfied
but no one who has 2010 and solves it so then I see how he did it?
I feel like Mongolian.
if you can't put that bond means there are other constraints that overdefine it.
analyze and try to figure out where the problem is. dismantle and reassemble, suspend and reactivate components and couplings... also and inevitably in this way learns.
crazymad, try this solution and adjust the "excursions" as you need.
However, you should model with more knowledge; learn how to use the plans correctly, make the "symmetries" parts compared to the main plans. This helps you a lot in the couplings together.
You have helped me a lot.
1 I would like to understand how to put the main axles in the middle of the piece
2 because sometimes symmetries do not work
