assembly problems
  • Thread starter Thread starter Yellowmode
I have a problem, in the image you can see that there is a piece of rubber (the one marked in green) that obviously deforms and adapts to the model. the prof recommended me, in order to avoid complications, to model it directly on the assembly, but I should make a 3d schetch! What I can't/I can't do in the assembly!
by the assist do:
- menu insert
- creates component
- the possibility of creating a new piece "on the place" that is attached to the existing geometry
- click on a flat face where the piece of rubber should be born and pull the sketch you need and make relative feauture
Note: If you do everything well, cover the reference geometries your piece will not need additional constraints for positioning but will automatically adapt to the position of the objects "connected" to him, except then to render inconsistent the model (i.e. if the lines intersect you the model will disappear and there will be error)
by the assist do:
- menu insert
- creates component
here I am, I create a sketch on the pre-established plane, but the feature?
I mean... I don't understand. .
by the assist do:
- menu insert
- creates component
tracked the sketch and after that you do the function you need, sweep or extrusion or whatever you want. You can do more sketches and work them. You will definitely use the "project on the floor". ...
Yes the first schetz with "the silhouette" I know also do, the problem is to draw the schetch with the path of the sweep! as it does not have to lie on a plane, but I would need a sketch 3d that on the assembly where I am working you can not do!
It's not that you can't.
# insert new... on place etc
# Stick to a piece
# You're in 2d sketch mode
# Get out of editing part and licking twice in the top (in the feauture manager... the tree aside)
# Click twice on the birth name
# Now choose 3d sketch and do what you want with the geometry of the axieme components under clear
try and see what funzica:wink:
