rosariomartino
hello to everyone, I'm at first with inventor and I would like to ask you a suggestion.
for work, a few years ago, I made a crane with rhinoceros. Now I'd like to try and rebuild it in the inventor but I can't figure out which way to follow. the crane consists of a boxed (see example image) made of sheet of various thickness welded between them. I can't understand if I have to make the single sheets and then assemble them with complacent constraints or if I have to use the welding environment. I would be grateful if someone could give me suggestions and/or references to learn.
Thank you in advance. . .
