assign me in separate base.
leggera
I assume my answer is already in the forum, but I don't know what to look for.
My problem is to tell the asses what to see in separate his parts and what as together.
example:
I have a combination of 3 subaxis b c and in turn composed for simplicity of 5 parts each.
I have the possibility to see the 3 assemblies or see the parts under the assemblies b c and total 15 item.
If I wanted to see in my separate axieme b + 5 parts of the axieme c + 5 parts of the axieme d so 11 items total as I can do?
Is that possible?
thanks and good day.
you must correctly set the type of each component.
If, for example, impose a set as "hidden", in distinct will appear only its under components.
