assign parameters value from external file in creo
Lucius Fox
Hello everyone,
Does anyone know how to import strings contained in a text file and assign them to existing parameters in creo?
example:
I would like to create a macro that assigns to the parameter "description" the value "lamiera thickness 5" contained in a saved text file, for example, on the desktop.
I don't think that's possible.
you import parameters with their values from a file, but you do not import parameters values.
you have to use a '.xml file; not a simple text file.
for example a file with desired parameter:
xml version="1.0" encoding="utf-8"?<creoparamset><parameter name="descrizione"><datatype>string</datatype><value>sheet thickness 5</value></parameter></creoparamset>then create the macro with import this file into the parameter menu.
hinges
