assignment attributes to polygonal
  • Thread starter Thread starter tungsteno
tungsteno
I would like to understand if all I'm going to ask is feasible or not with autocad or with some similar program. This is very difficult to explain but I try.
I have catalytic maps in dwg format. I would have the need to attribute particles, in this case represented with closed polygonals, certain samplings. I would like to avoid a long manual value.
as first I wanted to understand if it is possible to associate an identification number with a polygonal (e.g. the mapping number).
Once this is done, is it possible, by autocad itself or using extensions, to give the input to sample certain polygonals automatically? (eg give a command to sample the particle 1 and 2 of red and 3 of yellow. . )
Clear?
thanks for the attention!
I would opt for a ni, clearly with programming, not with normal autocad commands.
If, however, our metal colleague should use it at a utc, it would be better to consider a special software.
