assisted installation creo
  • Thread starter Thread starter millegno
millegno
good evening to all, I no longer remember the command to install proe (creao ) normally, insert the cd and always leave the assisted installation.
Can you help me?
I know only one type of installation, can you explain yourself better? What do you mean to install creo normally? What version of creo use?
when inserting the cd / dvd can start both the classical installation where it shows you id machine and then enter the path of the license file.... or start the one where you are asked first the license code and then give it the path and on top you read written installation assisted..... you can proceed to the first going on run and writing g:/setup.exe and then nnnn remember the other parameter. . .
As regards the mode of display and approach in installation, I find that it may vary from
version (e.g. creo 1 and creo 2) and also revision (e.g. m030 and m040).
I haven't used cd/dvd for a long time, always unload the total zip of proe/cree.
so I use only one system to install, that is:
creo 2.0\ parametric\ bin\ reconfigure. exe I thinkwildfire4\bin\ptcsetup.bat with the wf4 and previous
I don't know if you're useful
