associate storyboard with instant view
  • Thread starter Thread starter Massi2809
Massi2809
Good morning.
use for some years inventor, currently they are in version 2023; in the management of presentations, I happen that the instant view on which work is not associated with the main storyboard, this prevents me from updating the
drawings in .idw. Is there a chance to connect it or should I create a new instant view?
or
Good morning.
thanks, but the links do not reflect what I look for:
the storyboard is updated (the two indicators are aligned) and I don't want to continually change the instant view.
I would need the instant view ("view 1" in the example I have attached), now, independent from the modifications of the main frame, to be aligned with the .ipn file changes.
the discriminating between the two situations is (I think) the presence of the tab indicated in "view 2" . is this possible?
if you try to erase instant and recreational views at the desired storyboard point?
if I delete the views and then the ricreo works, but I can't delete the instant view as connected to a .idw file already balled.
is it possible to put the "language", indicated in my example in view2, in a view that does not have it? (view1)?
