dadinux
Good morning.
before you fall for opening a post on a topic already discussed on other occasions...
I have really shunned in the long and wide searched in various forums, throughout the web.
I have big problems understanding the process to move from a table (which is it in access, excel, word, fiel *.csv, etc...) the data that will upgrade the various attributes of a certain block in my autocad file.
For example, this "filter" is written in the block selection:
ï ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄ ̄set sset2 = thisdrawing.selectionsets.add("nomeselection")
dim filtertype(1) as integer
dim filterdata(1) as variant
filtertype(0) = 0
filterdata(0) = "insert"
filtertype(1) = 2
filterdata(1) = "nomeblocco"
'¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯How does this instruction block work?
'I copied it and it works but I didn't understand the syntax well.. .
I mean... with what criterion do I use filterdata(0), filtertype(1), etc...?
' ok copy it and take it for good but... I would like to understand
The syntax...
filtertype(0) = 0
filtertype(1) = 2
The syntax...
