autocad 2010 64bit does not remember settings
  • Thread starter Thread starter pcgame
pcgame
Hello everyone, I am a new user and I must immediately ask you for help.xd.
as from title my autocad 2010 does not remember the settings I give, in fact can not remember the snap distance, limits, and others.
I solved partially importing from cad 2006 an old profile, but some settings are not changed
what is this problem due to? ?
It's really annoying.
....but some settings are not changed
If you refer to workspace settings, with setzadl you can set the automatically save to any change that is made to the work area (which cannot be automatically saved in this case). better the Salvadoradl command where you decide to save when you are sure of the changes made to the work area.
I refer to the set-ups that are there if I click on the snap-> setting button.
However, by saving the working area the settings regarding the snap always remain on 10(default) instead on 1.also changing values(15/30 etc...)the field at each closing and subsequent reopening of autocad returns to default.
if however I try to open a drawing already made with such settings these are there. .
the values you refer to are stored in the single design, not in autocad.
That's why you don't find them when you open drawings where you didn't give these settings.
if you always use the same values created a template with those settings.
