autocad 2010 crashes with 3d orbit command
  • Thread starter Thread starter Jokerinoprogrammer
Jokerinoprogrammer
Good morning to all,
My brother bought a hp pavillon computer with 8 gb of ram , i7 , video card dedicated by 2 gb ati , and I installed autocad 2010 at the beginning all right, for a month is finding the following problems while running the 3d orbit command and preparing to turn the object the program freezes and requires the start of the application , or when choosing the 3frame wire view.
Now I wonder, is it a video card problem, or a computer program or something?
I hope someone can tell me the right solution.
ps: Also last week with this issue in place I decided to update the drivers of the dedicated video card, but the same problem has not been solved, and when I try to make an autocad update I am blocked by a message that indicates that it is impossible to download update as I am not enabled to do this change.
cordial greetings
win
Hello and thank you for the straight, and that I should install on a computer of 8 gb of ram, a 2014 autocad? what you say could be okay? or installing the last update you recommended for autocad 2010 the situation is resolved? But I don't think there's any compatibility between windows 7 and autocad 2010 I don't think it solves anything you don't think?
thanks for your help
I have a 2014 license. What do you say is everything?
- - - updated - - - -or could I create a second partition and install windows xp and autocad 2010 what do you say?
mah, in all sincerity I did not know this official limit of 2010 on 7 x64.
I quietly installed it and more with an old amd card. I just changed sk. video (amd per amd) and I keep not finding any problems.
also my relative, with a portable hp win7 x64 and sk video firepro (so amd) installed 2010 (obviously in x64 version) without problems.
But if Mom autodesk says that there's little to discuss. even if to ensure compatibility with view and npon with 7 is a beautiful wedge on the feet.
p.s. but the minimum equipment reported by mother autodesk, is it not that it is referred to the s.o. available at the time of release of the program?
I mean... difficult that autodesk can say "autocad 2014 - minimum requirements windows black tiger" when the s.o. "black tiger" will be released in 2016... :biggrin:
p.p.s.
I always discarded nvidia just because inside autocad the video drivers of these cards were not indifferent.
in which sendo " is a break-in of boxes having to continue rebooting to use autocad ? ie' in the sense of rebooting and choosing the partition to use? You mean that?
look what I found on the internet, in an article
this post is just a first overview of the features of autocad 2014 and who would want to see new commands on the 3d, in this version will not be satisfied. the 2014 autocad is compact with windows 8 and for those who own a touchscren will be able to exploit some features you select, edit and zoom, although still the use of the mouse remains obliged, as for example, with the touchscreen, it is not possible to emulate the functionality of the right mouse button, to open context menus.
What do you think you should try, don't you think?
maybe because in 2009 when that version win7 still didn't exist?! (or was only in beta). .
never had a problem. also autodesk heads its products with hp workstations and nvidia cards
depends on what design/model. as long as you stay on 2d are more than enough, but in 3d ... well autocad is renowned for its fetecchia performance in 3d :p
excuse me and how many gb it takes to make a 3d with 2014?
and if you try to install 2013 you say 8 giga for both 2d and 3d would be optimal?
problem 1. autocad 2010 is not compatible with win7 x64
tristan in fact that I wanted to say: can not be 2010 incompatible, with a s.o. that has not yet been released. what you linked to are the requirements minim officers, of course at the time of release of the release.
does not mean that if win8 is not included, it must necessarily be incompatible, does it?
Right. Let's put it this way: since autocad 2010 was released before the release of win7 it was not possible to carry out any tests, then autodesk does not support that product on that os (of the series...if it works good for you, but if there are vents you attack)
Well this is definitely the policy of all softhouses, but not only for untested products:wink:. always declare it in licenses. exemption from damage caused, the soft is sold "as is" etc. etc.
in all cases one thing is "or the go or the split", another is not compatible. for my experience. win7 64 and card (piu d'una) amd la 2010 spins smoothly. It means that it's the joker car that has problems, not the outline conditions.
My brother bought a hp pavillon computer with 8 gb of ram , i7 , video card dedicated by 2 gb ati , and I installed autocad 2010 at first all well , for a month is finding the following problems while running the orbit command 3d and you learn to turn the object the program freezes and requires the start of the application , or when you choose the wire 3frame view.
Apparently your brother always has problems with 3d orbit:
http://www.cad3d.it/forum1/showthread.php?32258
Good evening to all,
the problem of autocad 2010 has been resolved I have mounted on the notebook of my brother autocad 2012 and I must say that it turns very well and not from too many problems.(cut)Thank you.
