autocad 2011 in crash con stampante hp laserjet cm1312nfi mfp
  • Thread starter Thread starter massimop72
massimop72
help if I use the hp printer mentioned above, I automatically close autocad. Can anyone help me?
installed the original hp drivers or compatible drivers?
Is he just doing it with that printer? Have you tried with others?
installed the upgrade for autocad 2011?
other question I would ask is this: Is the pc connected directly to the cable printer, or indirectly via lan network?
the drivers are original, the printer is wired and with other hp printer (photosmart pro b8350) everything ok
maximum,
You have to have some patience.
1] Does the problem arise only with autocad or even with other programs?
2] in autocad, do you use the generic driver for windows, or the dedicated autodesk?
maximum,
the problem arises only with autocad. as to the driver I do not know how I can see if I use the generic of windows or the autodesk but I presume that of windows
Then, if I were there physically, I would act with this sequence:
1] current driver uninstallation, according to sacred uninstall crisms type from control panel
2] cleaning of the register by ccleaner
3] machine restart
4] driver installation for your operating system from This is site (and no one else in the world, trust me).
