jim78b
in a design I don't know why when I use construction lines that intersect normal lines I don't find after the intersection. I have done everything overkill flatten...etc nothing
Thank you so much you were very helpful! !He just doesn't find it.
Put the units to 8 decimals and you will see that the block is not z0. then explode the block and you will see that no line has the same plan z.
