autocad 2013 does not charge the ribbon bar
  • Thread starter Thread starter 19junior86
19junior86
hello to all
I have the following rather strange problem. opening a .dwg file, it opens, but does not load the ribbon bars (cards and groups). charge only the "fast access toolbar" that is up.
the only way to view the above tabs, is to open autocad by clicking on its icon (and then opens me "sign1" blank), and then go to open my file.
often, however, I forget about this and accidentally open the .dwg file first (not loading the menus). Then what do I do, I close the program, I reopen it from its icon... and this time it happens that ribbons don't even appear like that. The only way to make them appear is to type "ribbon" on the command line. precise that if you type "ribbon" on the .dwg file, the bars do not appear. must be typed only on the blank "sign1" file.
all this happened to me long ago after installing another application (provided) that ran .dwg files, which I uninstalled almost immediately, but created this annoying problem.
No.
that problem was another, by the way, I had autocad 2010. among other things it has solved simply by installing autocad 2013
could also be something to do with the launcher since the problem does it with the direct opening of files that I think you do directly from explorer
I just tried, with that variable, nothing changes.
As for the launcher, it opens it with "autocad application" with the icon of as are the icons of .dwg files
hmm... I solved!
opening it with "autocad dwg launcher" the bars appear!
Now that I remember, I had put autocad application ago because with autocad dwg launcher I opened the other application. And I left him like that.
thanks massiconweizen
