joeblack
Good morning, everyone.
with autocad 2014 64 bit on a pc with windows 8 64 bit, I have the following problem:
like every morning, I look for the folder of the practice on which I am working on my pc, I find the dwg that interests me and with the double click on it, I start autocad.
well you will say...
the problem arises when I have to insert an image.
as I always take the image from the windows folder and with the drag&drop I insert it directly into autocad (later me the port and/or resize to my liking), as I always did.
When I release the drag&drop key, though... I crash autocad!
same thing if I do all the ordinary steps (i.e.: from the ribbon menu "insert", command "allega", then I choose the file from the path on the hd, etc.).
the strangeness I noticed is that, instead, if I start autocad from its icon, then I open the file using the command "open...", I can insert the image! even the drag&drop works!
Has anyone of you already happened? ? ? ?
