autocad block on 64 bit system
  • Thread starter Thread starter russacani
russacani
hi to all, I have a big problem with autocad: after finishing the installation of the sw, after having made 3-4 alerts of the program, as soon as clikko buttons as you open, save etc the sw goes in block. I can't figure out what it might be, could you please help me?
Try to install the autocad service pack?
ps: in these cases always specify the version of used autocad and the operating system.
I have windows 7 ultimate, and I tried with autocad 2009-10-11. I don't think it's a matter of sp, do you think?
No, I don't believe either at this point (even if tempr never harms).
tried to disable any antivirus?
does not generate the file of the registry errors?
opening it with the note block shows a code of the generated error.
I don't know how to see if it creates this file. Where am I supposed to find him? However, he considers that he goes into lockup and I have to force the arrest. does not appear the report screen to be sent to autodesk
I think you have to have the version of autocad version 64 bit, I had to request also I an update of visi to make it turn with the 64 bit and windows 7.
ps.not an update but a file that sent me.
It is a .err. file that is created when situations like this occur.
find it in the folder where the file you open is located.
autocad has no update file for windows 7.
tonight as soon as I get home the .err file. cmq in the network I found a possible solution. someone talks about services disabled. rethinking in fact I remember disabling services long ago. and I'm sure he started to trouble them. the point is that now I have no remembrance of which I can be. Should I try them all... or would anyone have a suggestion?
As history has been going on for about a month, I don't know if it's the case of restoring a point more than a month ago
