autocad commands in vba6
  • Thread starter Thread starter tiziano69
tiziano69
Good morning to all, who gives me a hand to solve this problem if possible. then, I created an executable in vb6 (not vba) through which, I send the classic editing and design commands to autocad, and until here there are no problems, the fact is that I would like that once passed in autocad, the form hides and reopens in the same position once the autocad command is finished. for those who want to try, for now only the "linea" command is working. I also provided two possibilities, one before the form is always present and superimposed to other applications (case of two monitors) and here there are no problems, then through the "hide" button I return the form "hidden" but I cannot restore it in its position after completed the autocad command. I have attached files to the project.
I tried but I couldn't.... Thank you.
I answer only now because it was influenced... I used vb6 because it is the only one I know together with the lisp and the vba.... I'm an old-time designer. However if someone is able to solve the problem place, well come.
