autocad configuration 2007 for mechanical design
  • Thread starter Thread starter ospiccio
ospiccio
Hello, I kindly ask if through the function imported from profile you can as described in the subject; Thank you.
from which autocad you must export and in which autocad to import? You don't understand your question very much.
Hello, thank you for reading the post; the version of autocad to import is the classic 2007 for architectural design; the configuration by mechanical design in addition to the classic method(measurement units, quota styles, tolerances), I asked if it was possible, to speed up the work, or to use the function from profile, or some alternative solution I ask you politely; Thank you.
