autocad layers - squares and carts to load on inventor
deep70
Hello everyone,
I premetto che autocad has for a century that I do not use it for several mainly working reasons, I still find myself with this problem.
a client asks me to make a meal with inventor, using the cartilages that generated in pprecedence with autocad, now the problem is that when I load on inventor this blessed file.iwd the sheet appears completely white, I tried to open it with autocad and also the same thing, you absolutely see nothing, when I think there is something stuck in the layers on autocad. but unfortunately I can not unlock or perform any operations in the layers.
In the photo I posted I used trueview, I guess it's the same thing from the layer point of view... I apologize for the bad quality of the photo but I'm out of office, I hope someone can give me some tips.. I entrust myself to you gurus of autocad.
thanks to all for any answers and good work/day to all.
What does it have to do with mechanical?
is not the inventor's section anymore?
What should be in the drawing? and where, in the model or layout?
I posted the discussion here because the source file was created with autocad, so a possible modification presumably should be made on the original file and with autocad precisely.
autocad users are not told that they read the mechanical section being this specific to the program
autocad users who do not use inventor can not help you.
who uses inventor probably already had
what to do with the interaction between programs
I understand, then I move everything on the inventor section.
