autocad lt 2009 header bar gone
  • Thread starter Thread starter mirco28
mirco28
Good afternoon,
after trying them all I wanted to ask you if you know how to make "surprise" the header bar where you can read "autocad lt 2009 - [nome file]" on which he is working. PCs have been replaced in the office and, after reinstalling the software, such bar or is gone, or is in transparency. I then tried to reinstall and repair the softwar but nothing changed... that it is the fault of windows 10?
If you know how to help me, I'm grateful.
Hello everyone and good Sunday!
to tell you the truth seems to me in transparency, but it seems to me to have read around, that it is not possible to change these interfaces with cad lt 2009... sincerely it seems strange that the bar that reports "autocad lt 2009 [nome file]"it's gone.... it's actually that I can't read the file name and that I've tried them all to view it!
to tell you the truth to me seems in transparency
If you can't fix it you have it in front of your eyes....
sincerely it seems strange that the bar that reports "autocad lt 2009 [nome file]sia sparita.
But wasn't it in transparency?
not to make the controversy, but if you are not the first to give clear indications about what you see (only you) how should you help? shooting cold hypotheses and hoping to get the winning one?
there is then the autocad section for specific software problems
parts from this https://www.cad3d.it/forum1/threads/50646-cambiare-colore-alla-barra-con-il-nome-del-file and this https://www.cad3d.it/forum1/threads...-alla-barra-con-nome-del-file?highlight=barra
I'm sorry, maybe I've been wrong and maybe I know too little about the new operating system: the words "autocad lt 2009 [nome file]"I can't see it on the new pc but probably the problem solves it from the link you reported to me. I think the bar I'm talking about is part of the autocad screen so it's probably in transparency. tomorrow however I check the windows settings on the pc station and then I will let you know if the problem has been solved.
thank you and good Sunday
barra intestazione trasparenza.webpgood afternoon, the header bar is in transparency but I do not find the settings to change its properties, or better, from the control panel of win 10 by putting the "high bump" I try to read the bar but obviously all the settings of the pc are changed!
Am I wrong or is there an autocad setting to change?
thanks and good work to all
ok, thank you, it is true, if I click on the icon the name appears but generally passing from one window to another you are bar with the file name...in the sense that so doing you "Mangi "a piece of monitor!
However rather than nothing better so:biggrin:
