autocad lt 2009 pastes objects to the contrary
  • Thread starter Thread starter ttg
ttg
from Friday I have this problem. If I cover an object and try to paste it on another table, it is glued to the contrary, as mirrored! If I try to mirror it to turn it, it is not mirrored! If I create a block, paste it with the mechanical part "right", while with the words on the contrary!grrrrrrrrrrrrrrrrrrrrr but what happened?? ? Thank you so much!
with the "mirrtext" command set to 0 you can at least get that the text does not mirror:wink:
mmm...I have to try the mirrtext!on the fact that they modified me variables could also be!mannaggia to them!
At this point I would ask you to attach the two files that give you problems, even removing all objects except 1 block, to check all settings and variables.
hello to everyone... don't ask me how, but it's back to normal!
Thank you very much for the support!! thank you very much!
