autocad lt 2017 goes to snaps
  • Thread starter Thread starter x11start
x11start
to work use (devo!) autocad lt 2017 and after about 10 minutes starts to work out: move your mouse and wait for that couple of seconds that the pointer will follow you.... and when it does, you have already moved your mouse.... so in the end you can't click on the line.
the pc is very recent with windows 10 and 8 giga ram... (I don't remember the other features).
the only solution is to go out of autocad and return.... but to do this 80 times a day, it becomes a bit frustrating!
other problem is the f8 key (to insert the garden): is not "transparent"... i.e. you cannot use it during a command.
did you notice if this behavior happens after changing a block?
It happens to me that after changing a block in a drawing, acad slows down a lot and becomes "fucky". The only way is to save, exit the drawing and return.
for the "transparent" garden controls in customization (here) if in keyboard shortcut and in temporary override if there is the aprostofino before the command that makes it transparent
thanks crystal: Tomorrow I will try to check if the "colpevoli" blocks are, and the apostrophe for the garden.
(they were good times when a rake and a rake were enough for the garden!); )
There's a reason for that autocad behavior. Undo. in reality autocad keeps in memory a version with the new block and a version with the old block, so that if you cancel the changes, he can go back correctly.
saving and leaving, autocad empties this temporary situation because it cleans the cache of the annulla.
in fact are the blocks that slow me down the cad: on lt there is a way to reduce a bit the memory dedicated to the cache (at the expense of the number of "undo" usable)... or a command that emptys it, without having to go out and return?
As far as the garden is concerned, it's just the f8 that gives problems: well... I can always get used to using corn+l.
It's very intuitive. "the state to indicate "the garden".... ;)
no you can't empty the cache on the fly, because you'll lose all undo functions.
But if you don't redefine the blocks every 3x2 I don't think it's so annoying to save, go out and come back immediately.
