autocad map 2013: problem connection data raster
  • Thread starter Thread starter geomarco
geomarco
Good evening,
I am new to the forum I make the geologist and for a few days use of autocad map (version 2013)
I created a card in which I connected imagina raster .tif and .asc from the task pane as following link: http://knowledge.autodesk.com/suppo...50d23713-5174-4f1e-9220-2a3f86c9d278-htm.htmlI saved everything in a file.dwg
I have the following problems:
1) when I open the file.dwg on another computer the raster data turns out disconnected and the impossible notice appears to open fdo connection (the file.dwg is always contained in the same folder as the rasters in question)
2) if I create a print layout and try to print it as I could do in a normal autocad design the program crashes
Can someone help me?
