autocad map: select objects based on the data object
  • Thread starter Thread starter Clod75
Clod75
Hello, I would need to select objects based on a specific object, on the net I find nothing and can't come out of it. . Would anyone give me a tip?
thank you so much to all and good day
with selerapid you can only use properties to distinguish objects to select but not the object data associated with a line for example
you can query the current card from the task pane, thus creating an information layer based on the selection policy set on the od
