ciao_
Good day to all,
I just started using autocad mechanical 2015 while it's been using inventor for a while. what I should do is make the model of a set in inventor and realize its table in autocad. for the model of the assieme no problem, while the troubles arise when I have to make the table. in the table I should make a view where you see a component in 2 its different positions, I should change a view to make continuous lines drawn, and I should do a decomposed section. thank you very much in advance for the help
