autocad performance problems 2018
  • Thread starter Thread starter Giuseppe1987
Giuseppe1987
hello to all I have a 15 inch gaming 7567 inspirion laptop with the following features:
monitor 4k
processor intel 17 7700 hq
video card gtx 1050 ti 4gb
Ssd 2.0
16 gb ram 2.4 ghz
I have installed autocad 2018 version students, and it is not that it is not fluid however from this expected hardware more sincerely when I move the cursor known a bit of slowness but above all a not fluid movement of the pointer instead known a greater fluidity on the pc of my colleague who has a fixed pc always of with a monitor connected 1240x1020 one thing of the kind, then has an i5 of the previous generation, an integrated video card
because a 2018 is much heavier than a 2015
because working at 1650x1080 is much more likely than working at 4k
because a fixed is a fixed one that says many. power stability, heat loss... It's all another planet.
I have a fixed i7 7700k and a laptop i7 7700hq enter me 7th generation, both quad cores. the fixed travels me to 4,3ghz the laptop to 2.8 ghz, think you.
However, I am now doing simple motion tests of the cursor and I am seeing that with the integrated card it goes slightly better than the dedicated one, I can't say why, I disabled the dedicated video card, when I activate the video card dedicated to the management of activities however known that both work, instead if it works alone 630 seems that the cursor is more fluid, mah.
Very strange. try to update the drivers of the dedicated video card.
do some tests, even with other software.
the drivers are up to date, I explain better, when the video card is active, and start autocad 2018 from the management activity known that the program still uses them both noticing while working a percentage that varies for both but the performance especially in terms of fluidity are very similar indeed to the naked eye is very difficult to notice the differences when instead I start the program with the dedicated video card turned off, sincerely I can not understand why of this not difference card, maybe something is dedicated
deactivate from bios the built-in video cheda of the cpu and do tests....you will have to bang your head until you adjust the correct settings.
I agree with what you say... but the i7 770hq does not reach up to 3.8ghz?? the two pcs that I have in signing while being a fixed pc i7_3820 3.8ghz stock and 4.2ghz in oc and a notebook with i7 4800mq at clock parities have roughly the same performance, of course in oc the fixed from about 10% more performance than in some operations you notice clearly in others no depending on the software I am using.
If I make a comparison between my precision m6800 and my colleague's asus at equal cpu his heater as an oven and in the fem analysis went to "beau women" my monster had about 30°c less and finished the analysis in beauty.
taurus, I said a chestnut on 7700k.
in standard phase (without oc) an i7-7700k goes to 4,2 while an i7-770hq goes to 2.8
in oc the 7700k goes to 4.5 the 7700hq goes to 3,8, but you see it in cases of heavy stress, the processor does not go to oc to move the mouse, which perceives juseppe.
for the construction quality of laptops I agree with you, there is a world of difference (the laptops are very sensitive to optimization)
a laptop is a compromise.
castrated in performance (for dissipation, for consumption..), in expandability, in longevity, but perfect if you have to work out of place (you know what flash would go to work from the customer and carry back in fixed with the external monitor. . )
but if you have a place where you usually work and need a pc, then I fix your whole life.
Let's put it like this: if you do the transporter, you have to have a truck. It can also happen that you use your suv to bring a TV or a fridge.
but if you do the conveyor, you can't think of using only the suv, otherwise you will be limited to bringing a refrigerator to the maximum. .
in my opinion the problem is not the hardware, extremely oversized but the software that does not manage the graphics card nvidia correctly.
autocad 2018 turns on a core2quad from 2.5 ghz, 4 gb of ram and a graphic card radeon 6870hd smooth as oil, confirming that your laptop, clearly more performing should not have problems.
autocad does not create problems of decrease of performance due to the increase of temperatures, if not engaged in rendering, uses 1 core of the cpu, practically irrelevant.
once the notebooks with dedicated graphics, they only had this, they consumed more but they were ready, even with autocad, like the fixes. Today they are obstinate to flank the dedicated graphics only to manage the 3d (videogames) and leave the 2d to the integrated intel, only for problems of autonomy, a total crap.
then add the presence of the 4k and you have reached the apex of the useless, force the intel graphics card to manage a huge amount of data that is definitely not able to do it at best.
solution? Look here:https://knowledge.autodesk.com/it/s...ita/autocad-uses-the-wrong-graphics-card.html
