autocad performance slowdown problems
  • Thread starter Thread starter Simus89
Simus89
The problem is simple.. from a week of point in white autocad began to give problems of fluidity, I explain better .. as soon as I start the program all ok , I click on commands like : rectangle/spline etcetc and everything goes smooth like oil , but just touch simpler commands (line/poliline ) for the sudden decrease of performance I can not even merge two lines with precision or about"
[Info]the pc should not be a problem:
acer aspire 7738g
processor intel core 2quad q9000 2ghz 1066mhz fsb
graphics card nvidia geforse gt130
4gb of ram ddr3
-autocad 2012
Thank you in advance
:biggrin:​
Unfortunately yes >_>" at first I thought it was due to the heaviness of the file, but also with empty file and pc "fresh" goes to shots
even if that's not the reason, try installing the autocad service pack if you didn't.
as an extrema ratio attempts to restore system configuration at a date prior to the one in which the problem occurred.
I would like to avoid uninstalling it momentary cause loss of the exe file of installation ^^^"... cmq I tried the restoration from the dinistallation menu and also with the restoration the problem persists, I am wondering if perhaps duly I touched some setting that I had to touch...is there any setting that can affect costs so much in the performance of a single and specific stumento in autocad?
creates a file, of those who go to slow motion, post it, at least trying it in another machine we can exclude a whole series of problems.
bye
Maybe I didn't say that before and I apologize, but the problem is not caused by the file weight, if so would there be a xd sense. The problem is that all this happens on new files with "white sheet"
may be that the template has been inadvertently overwritten and now contains elements that cause that problem.
