autocad problem - how to remove "gunball (?)" 3d drawing 2d
  • Thread starter Thread starter fsts
fsts
Good evening,
after some research (unsuccessful) I hope to find help here.
suddenly in the design of autocad appeared, on the lower left, this command:
gunball.webpsince this command appeared the design is extremely slow. How can you remove it? It seems to me that the design has become 3d (not voluntarily...) but I can't find the way back to the 2d.
friendliness
I think it refers to the fact that you set the 3d display mode rather than the 2d.
_vscurrent command with option 2 (2dwireframe)
Exactly, it works! now autocad is as fast as before.
ok!.webpThank you so much, you saved me!
thanks to both for the help!
Good evening.
It's the ucs icon. try also to make it disappear with the ucsicon (off) command even according to 3d display mode, in case you have to go back on that display mode, to see if you will feel that problem.
