autocade 2014 and area calculation
  • Thread starter Thread starter pivaino
pivaino
hello to all I have the following problem and I hope you can help me.
I should, with autocad 2014, calculate the area of a surface (made) by subtracting from it the holes (windows, etc); I wanted to use the add command and then you will subtract areas only that I noticed that it no longer works as in previous versions (until 2011) in the sense that while first adding areas I remained the green nets displayed and also subtracting the areas remained the red nets now instead after adding an area by pressing sending me the green net (however, giving me the possibility to add or subtract the areas).
I don't know if I've been clear, but this makes me a bit of trouble because I have to remember which areas I've already added/subtracted while before the fact that the green and red nets were displayed helped me understand which areas had already been treated.
esite a setting to set?
