automatic comparison (or seeds) of two ipt components
  • Thread starter Thread starter windreef
windreef
Hello everyone
exists by chance a method to automatically compare two similar ipt pieces in addition to the classic insert them in coincidence in a set and verify it visually changing color to the components?
Thank you very much
banally, I would compare the physical properties of the two parts. If material, weight, surfaces, inertia, etc. are equal, I would say that, with good approximation, the two parts are equal.
hi, for the processing, example drilling or milling, comparing the only properties you cannot see which are moved, see a difference but you do not know where.
there are paid software such as transmagic sennò in inventor uses analyze interferences, or cloud appears that, in fact, two models , but it is free
I didn't think about it, thank you.
about transmagic, do you use it? but what price are you talking about? on the site is not indicated so usually brings bad... I read turns files into native formats, but of all software? i.e. file inventor save it in solidworks and for solidworks becomes native, with the processes ect? It would be very interesting.
