automatic design parameter
  • Thread starter Thread starter D4n13l
D4n13l
Hello everyone
I wanted to make sure that the 3d model automatically comes out the name of the designer who creates it, so that then this parade I connect it to the cart.
Currently, however, this parament is handed out every time you create a new piece, you know if you can do what I want with I create 4.0 or later?
I would solve it with a dedicated start-part for each designer with already the name of the compiled parameter to recall then in the drawing of the piece
Thanks for your answer but it doesn't seem like a great solution in a company.. .
I hope someone else has another alternative. .
If you have a pdm to manage the database, the parameter is easily available, without, the solution is to create dedicated startparts, but if you have many, multiply the starsparts for the various designers, it may not be the best choice, at that point perhaps it is more convenient, to create the cards with already the name inserted.
the pdm winchill we will have it in a bit of time and not even with that it will be just such a trivial thing to have the name of the designer, as you will have to act on every single station and change the name of the pc...
I don't understand what it takes to make ptc to create a value so that you impose within the program the name that is using it as it happens in inventor I don't think it is such a complicated thing. . .
...as you will have to act on every single location and change the name of the pc...
I do not think it will be the only solution, there will certainly be a smarter and less impatient way to do what you need
If those of the following ptc don't know them, I certainly can't know how to do it, I remain to what they told us to make sure that the designer's name comes out automatically on windchill and that is what I wrote above.. .
I stay more and more basic every day that passes than I use this program... .
Good morning.
in the pdmlink thing, you can exploit the parameters that use the username and not the computer name (see image) so a solution could be just this.1578990454600.webpIt is clear that it is not an immediate solution but you will have to wait to implement in pdmlink company and that I understand it will not happen very soon.
an immediate solution is to set a list of default values for the design parameter; you will have to choose your own and at least so you will not find different values for the same user, such as: tertiary, third parties a., ter. and., etc.
another solution, not just immediate but not too complicated is to exploit the batch launch to correctly value the parameter.
Good morning.
in the pdmlink thing, you can exploit the parameters that use the username and not the computer name (see image) so a solution could be just this.View attachment 55857It is clear that it is not an immediate solution but you will have to wait to implement in pdmlink company and that I understand it will not happen very soon.
thanks for your answer, business pcs do not have a user name but users are called graphic 01, 02 etc.. so you will have to intervene there (this had been done not to have to whenever you change person in utm having to create another new user in the pc)
I don't know how to create it, would you help me?
the launch batch to enhance the parade instead I don't know exactly what it is..
this for computers but I'm talking about pdmlink users who will necessarily be nominal and so you don't have to change anything.
for the list of values is enough look at the help of creo paametric.
for the batch, it is not trivial and we must feel private.
In fact you have to proceed with the pdm user name and not with the pc name, try to imagine if a workstation jumps and meanwhile you use that of a colleague available to give it, for windchill logging, it is only reconstructed the workspace cache and depart immediately, while if you go via computer name, you have to rename it.... really not efficient. . .
windchill parameters are blocked, to protect who creates and/or edits the document.
and then why who follows us as ptc asked to change user names of computer graphics 01, 02 etc.?
I prefer not to answer .. I have been working with ptc for 25 years and I can confirm that said also by 320i s that you use user names and not computer names.
I know that when we enter the windchill environment, credentials are required and we enter as graphics02 and the password of the pc... we don't enter with a designer username and I don't know why and I think the right problem is here?
it is not correct and if I can afford it does not make sense to use a pdm in this way because eventually you use users who are not users. in this it is enough that you start using windchill users with name and surname leaving the pcs the already defined name (need to have a separate ldap from the active directory).
the only windchill does not manage the thing, that is to enter with the users with their name? or need this ldap (I don't know what it is) you say?
I consider this an incorrect organizational choice, also because windchill manages development teams with e-mail addresses of people and I think now also with profiles of other direct communication programs (skype?), therefore having a pseudonym instead of a real name, would not make any sense.
ldap software, which manages users, is installed along with pdmlink. a company can choose that the data (users and groups) are driven by windows (active directory) or are independent.
in your case the company should use ldap independently so that you can use users/persons and emails.
Hello everyone
I don't have the work pc under my hand to write you the correct steps to perform but in my opinion it's easier than you think, in the company we have this configuration.
in a text file called paramalv are inserted the names of designers
start-parts and start-assembly are common to all indistinctly and the design or similar parameter is declared
in the config.pro, if I remember correctly, this file is recalled.
every time you create a new prt/asm file when you want to enter the name just go to the parameters table and in the column the names of the designers will appear.
