Zoro76
Good day to all
I'd need help solving a problem.
the topic I want to talk about is the perimeter ropes/trays in a c.a. structure.
I kindly ask if someone has the opportunity to help me develop a lisp that can help me in this job. Unfortunately I have no knowledge about it and therefore I trust experts.
I try to explain what I need.
the most I managed to do was to create a dynamic block with attributes to define the types of strings. in this block I wonder in sequence these things:
- Like rope? where I go to insert the progressive number
- the quantity of upper braces
- the diameter of the upper braces
- the amount of the lower braces
- the diameter of the lower braces
in the drawing that I attached are unfortunately drawn only 2 lower and upper braces at the corners of the bracket. what I would like to do is: according to the data of the attribute inserted, to draw the reggistaffa in the bracket. graphically the diameters are not necessary and neither the distance between “the balls” should not necessarily have a precise step; the important thing is that they are equally detached.
Then, on the plant, I need to associate the block “type 1” to the lines that “will be” automatically drawn with a lisp :biggrin:.
As for this second part, I reported in the attached drawing an example of how they should be drawn. from the edge of the structure I have to make an offset of 2,5 or 3 cm and from this line an additional offset according to the chosen cord. for example if the type 1 cord is 20 cm wide then the second offset will be 20cm; if the type 2 cord is 30cm wide then the second offset will be 30cm.
doing this will then (always via lisp) the possibility to add a sort of distinct or perhaps adding a textm in the block, so as to account the lengths of the drawn cords.
I tried to explain the best possible. If there is something that is not clear I kindly ask you to let me know.
in the meantime thank you all
♪View attachment Cordolo.dwg
