calacc
Good morning to all,
as from object I have created a set of excel type analysis features in order to automatically fill out product specifications.
the part from pro/e to excel goes splendidly I would say, compilation and any updates happen automatically (as long as you remember obviously to save the spreadsheet). But in the part from excel to pro/e it gives me some difficulty. after the creation of the output parameter, downstream of the calculation part carried out by excel, behaves well only the first time. a project change is enough and I noticed with regret that the value of this parameter (which has been &xl_<rownumber>_<columnletter></columnletter></rownumber>) is not properly updated by changing the analysis feature. by the way comes a message that says that this parameter cannot be updated.
the harmful consequence is therefore that it is my duty to manually edit the value in drawings with the risk of making mistakes!
I don't know if it's normal. versions are created 1.0 m050 and microsoft excel 2003.
how do you behave? can you update the parameter value yourself?
If this is not possible, would you know how to indicate an alternative path?
Thank you, soon
Thank you, soon
