automatic renaming tables of converted tables in dwg
  • Thread starter Thread starter Fandrix
Fandrix
Hi, I would like to ask if you have a solution to this problem I have encountered. I made a series of tables, and of these I converted some sheets into dwg as I have to bring parts into the cutting program. Once I have created the different dwg, if I cover the content in one dwg, the tables that come from solidworks are renamed identically. I attach image to both the problem and the properties of the table, which are equal. I wanted to know if there is a way to avoid this or if it is possible, when save the sheet in dwg, the table loses the property. Thank you very much.
tables become equal because they are blocks with the same name. to a block of autocad can correspond one and only one geometry. Therefore, for example, if a block named "type1" containing a circle is copied into another file containing a block with the same name, but containing a square, the inserted block will become a square.
explained the operation of the blocks the solution is to explode the block (to speak of table in this case is wrong) before copying it.
Understand, so there's nothing to disable from solidworks? only through the explosion of the block in autocad can I proceed?
