automatic replacement of cartilage
  • Thread starter Thread starter cop1
cop1
Good evening,
I have the 2020 version of solid edge.
I have to replace the background squares in a thousand dft, taking them from a source file.
Does anyone know if there is a macro or procedure to do this job?
Coptics
in this folder you will find a program called "batch" which among other things can replace the cartilage.
c:\program files\siemens\solid edge 2020\custom\batch\bin\batch.exe
Could the dir. "custom" have disappeared in Vers. 2022?
in any of our new installations is present (!? ).
I would really need the "batch" mark, but in version at least 2020, what I recovered from st7 does not offer the possibility to replace the cart.
e' un download separato
Is there anything for those who have previous versions? Unfortunately this voice is already missing on 2019.
I have a macro called "replace se draft file border.exe" which is probably too old and not working.
My problem is that if, using "design manager" I send a customer a copy of the work all the drawings in which the date is set as a "date of origin" parametric field are updated at the date of copying the file, which I would like to avoid. I therefore want to replace all current cartilages with new ones where the date of creation of the drawing is a static field.
I took the batch.exe of a newer version that apparently does its job: Start version 219, you see the cad opening and closing the drawings until the end of the set work, and the log telling me that it's all right: "successfully replaced background etc etc. etc. The problem is that then going to reopen these files I find them with the last updated rescue date, but still with the old cart. suggestions?
Problem solved: the reason for failure to replace is that I had to change a parametric text that was inside a block. the replacement procedure of the cartiglio still went to resume the block inside the current draft instead of that, with the same name, present in the new template.
I renamed the block in the template and now the replacement is carried out as planned.
