automatic rescue pdf
  • Thread starter Thread starter Dum
Dum
Good morning, everyone.
the title can be misleading.
I have the problem contrary to 90% of solidworks users.
since I installed a utility of my client, every time I save a table, he automatically creates me a pdf.
I don't even know in the small details, but when I'm doing an overall, it's more than usual, stretching my dead times a bit.
I think it's a "general" sw setting, because it does the same job in all the sw versions that I installed on the computer ( 2016/17/18) and not only on the one on which the utility is active.
I tried not to load the utility at the opening of the program, but still saves me pdf.
So I think it's something set regardless of the activation of the same.
Before opening a ticket with the assistance I would like to know if someone had similar "problems" and knows which item to uncheck.
I turned all the menus but found nothing that could be reported to this problem.
Thank you so much!
If he's been doing it since you installed the utility and not before solid it has nothing to do with it.
probably the utility has installed something that generates pdf and is untied by the utility itself.
go to tools>add and see what is active
Hello Masses, I did it and I unchecked the incriminated addition.
even on startup, so it should not be called into question, but it continues to save me. .
Maybe I'm talking a ticket in the day and I'm getting insulted by assistance. .
