Filo
probelma quite simple but to which I did not find solution. . .
I have a row of holes at constant pace, but that in the design phase, most likely, will be changed several times. for each hole there is a bolt with its washers. bolts, being forty, were inserted through "component series". Is there a way why when changing the pitch of the holes you can automatically update the step of the series?
if this is not possible that method you recommend me to always keep the pitch of the holes and the pitch of the bolts? I know that by inserting the holes one at a time I wouldn't have this problem, but it doesn't seem like a smart solution.
thread
thread
